Virtual DVR/NVR (for my IP camera's)
ST1
Good Day.
Can anyone recommend any VIRTUAL DVR Software?
I'm currently using AGENT DVR but it only records in a max resolution for 640x480
Google highly recommends "Blue Iris" for the retail price i can buy a DVR/NVR/ Hybrid....
Suggestions? recommendations?
I'm using Blue Iris (one version before the most recent one, can't remember if it's 3 or 4) but it's worth it. Can configure most things and very versatile.
Keep an eye out for specials and promos, where you can get it cheaper (that's how I got mine a while ago). Have tried a few other packages but none worked right.
I use ZoneMinder, its full featured and free. It runs on Linux though so might not be for everyone.
Another vote for Blue Iris here. It is pretty resource hungry though
Question is what OS you using cause I would recommend:
Windows - Blue Iris
Linux - Zoneminder
Good Day, i am using Windows. I have a Dedicated PC that runs DVR so switching to Linux wont be a biggy..
I have Seen good reviews on Blue IRIS but i can buy a HIK Vision of takealot for the same price...
If you just want vanilla recording then NVR is easier. The moment you want to get fancy with analytics then you’ll need a software based solution
