Hey team,
In short, I have a wifi setup that runs on 2 routers.
Router A: (Netgear DG834G)
- Wifi enabled
- ADSL line attached
- DHCP server enabled
- Set as gateway address on all static IP devices
Router B: (Tenda)
- Wifi enabled
- Hard wired into router A via LAN
- No ADSL account obviously
- DHCP disabled
- Static IP assigned to this router (obviously to be able to config it)
Now, both Vista and Win7 laptops, kindle, android etc. connect to the Router A Wifi and works perfectly.
All of the above EXCEPT the Vista laptop connect to Router B's Wifi and works perfectly.
- When the Vista laptop connects to Router B, the connection states "local only".
- Router A shows the Vista laptop is connected, via the "attached devices" log showing the laptop's IP.
- Vista laptop cannot connect anywhere, also cannot ping device, yet it has a DHCP assigned IP. (even used ipconfig /renew to make sure it's legit)
I've checked the Wifi connection settings when it connects to Router A and when it connects to Router B. All settings are identical. Again, it works perfectly when connected to Router A, yet when it connects to Router B it won't work, despite other devices working perfectly on Router B's Wifi.
Any advice/tips will be greatly appreciated.
- Wifi enabled
Router B: (Tenda)
- Wifi enabled
- DHCP disabled
