Vodacom please help
shazm
Hi there
I upgraded and got my Galaxy S4 active last monday.
This morning its giving me a message that it is not registered on the network.
I called vodacom customer care and they were unable to assist me. In fact the guy said pull out your battery and it should work. But its not working.
I tried to register on the network again by going into setting and it says its unable to register on network try again later. I have tried 3 times.
What should i do?
Has your Sim been RICA'ed successfully? That might be the problem. If that isn't the case, and things aren't up and running within 24 hours of getting it, I suggest you go back to the Vodashop where you bought the phone and work things out with them there.
I went to vodaworld and it turns out my lte line was deactivated or something.
still a bit confused cause i had 4g signal this morning before my phone stopped working.
but thank you to the guy at vodaworld for fixing it
