Vodacom prepaid LTE bundles
cavedog
PTA
Saw Smartcall advertise these prepaid bundles.
Not the lowest prices but somewhat okay for prepaid bundles. Vodacom also now has a Prepaid LTE plan that allows you to buy the same bundles except the 1TB isn't available directly.
A bit off-topic, when you move your prepaid SIM to the prepaid LTE, does it include 3G as well?
I'm not 100% sure but I believe so. The Prepaid LTE price plan basically unlocks these deals but then takes away promo voice stuff etc so they use it to control how people use the data. As a data sim and not a voice/data sim.
The prepaid bundles from store.smartcall.co.za works on any prepaid sim you don't have to change the price plan btw.
Thanks!
I want to move to their home uncapped, I have 100% full LTE signal on the farm, but I don't fall under the home LTE coverage on their map. Missing it about 2km or so. I have zero clue how to test it if it will work without taking the 36-month contract out.
What happened to data needed to be valid for more than 30 days?
