Vodacom Red Advantage - minutes question
nivek
Do they roll over?
I'm automatically assuming data doesn't roll over, know how we get fleeced in that respect
Thanks guys
It's Vodacom. So your assumption has to be right.
I think, when working with Vodacom, you can consider every possible outcome. The option that screws the customer the most is the one that they will implement.
On the Smart and Red packages, your minutes rolls over to the end of the next month. So minutes not used in December will be available till the end of Jan and then it falls away.
