Did you ever get your awnser? I am trying to figure out if you can login to the Advanced settings of these routers to change the ip adress and dhcp range.Hi All can anybody know if the Vodacom X25 Max 2 5G is network locked?
I know the Vodacom X25 Max 5G is not locked to a network.
Nobody has confirmed the Vodacom X25 Max 2 5G is not network locked.Did you ever get your awnser? I am trying to figure out if you can login to the Advanced settings of these routers to change the ip adress and dhcp range.
Please share that Username + Password combo so we can also take a deeper look into this routerNobody has confirmed the Vodacom X25 Max 2 5G is not network locked.
I can confirm the Vodacom X25 Max 5G is not. I've been able to test MTN, Telkom not Cell C to date.
There is a way to get too higher privileges than standard user on the Vodacom X25 Max 5G using a different username and password.
Looks like it's called "manager", helps me with setup at home.
I think it's just Passthrough you get access to in the menu.
(could be more, I just needed IP Passthrough)
