Vodafone live settings for SE K800i
lupinaro
Garden Route, RSA
Hi guys
Does anybody know the manual settings for vodafpne live for a SE K800i? I can get to the home page, but canot load the TV. I have swoped mine for a non branded phone. Vodafone's own branding is full of glitches.
I managed to set up my previous Nokia N80 manually so I'm sure there are settings ot there for this phone.
Please help if you can
Mike
Steaming
Hi Mike
you wil need to go to your setting, under internet settings you will find streaming settings ,you need to select the vlive apn with no proxies or home pages as the connection type.
This is the apn you created under Data accounts. it should work.
You also will need to change your java accounts in order to run apps such as google maps, Mxit, and Opera do not use the VLive APN for this.
Or pm me ill contact you to talk you through it!
Hi Mike
Hi Bundy
I can connect to the Vodacom server with my SE K800i. However, opening a web page on my PC is the problem. Can't see the server. Voda help desk ubable to assist. They bame my PC. However, 5 months back I could connect with my old Black Berry V7100. Must be some settings that need to be corrected.
Many thanks
Hans
Hi Bundy
Many thanks
Hans
Hi Hans
Make sure the phone is connected and that it is in Phone mode Not file transfer mode.
There can be a number of things that are causing this problem what error message is coming up, One of the things that i find helps, using the Sony network wizzard you need to creat the connection manually, the problem with it creating the setup automatically is that 9/10 times it seems to creat a connection based on OPTUS in Australia.
Th manualy connection only requires that you connect via dialup and that the number can be *99# or *99***01# the APN it requires: internet,. this usuallly helps, there are a few other things to check PM i will try talk you through it :)
