Voicemail does not work with car phone
KERU
Jozi
My voicemail does not connect on my car bluetooth connection.
I can dial all other numbers.
My service provider is Vodacom.
I see this is a problem reported widely.
Wonder if anybody else has the same problem and has found a solution.
I'm having the same issue! Have you had any luck? Using an iPhone 4, on Vodacom with a parrot mki9200
Found a posting which says the minimum digits to dial needs to be 4.
Trying to find a way around dialing just 121.
Seems to be a problem with the latest 4.2.1 software.
Tried that. It says the number dialled does not exist.
