Volta battery blue light flashing
Roelofswan
I have a volta stage 1 battery with lux power inverter. System works great but I noticed the far right LED light of the battery is flashing a blue light. Usually all lights are steady green, and flashes when charging. Now the light flashes blue. Anybody know why this happened?
The manual does not refer to blue LED at all, only green that indicates SOC, even my installer does not know why it is flashing blue
Odd, just let it be and see what comes next. If there is a support line I guess you can also give them a call, which is what a caring installer should be doing.
