REAPER
- Oct 4, 2016
Hi
I recently added a wifi circuit breaker to my gesyer to monitor the power usage, it's been on about 20 days now.
When I first connected the wifi circuit breaker the voltage was about 233v. Over the past couple of days the voltage has risen to 246v, today it even went as high as 250.53v.
One of my light bulb already stopped working, I'm worried that more lights and even my appliances will burn out.
I know the voltage is supposed to be around 230v, I will like you'll go give me any advice on how to fix this problem.
Do I need to contact the municipality to report this problem?
