Vuma Fibre, Afrihost D-Link DIR-825 Issue
Chris888
Hi all,
I just got fibre installed last week. It is a 20mbps Vuma line, with Afrihost as the provider.
I am using the Afrihost provided D-Link router, and am having issues.
If I connect my Mac directly to the Huawei ONT things work well, I get a download speed of arounf 500/600 kbps.
If I connect the D-Link router to the ONT and then connect to the router over Wifi, the connection is sporadic. Something like a speed test will work fine, but if I try download something the speed will drop significantly to where the download is dropped completely. Also web pages will be loading fine, then will slow down to a crawl, then work again. I don't know what the issue is as my mac is literally 15 meters away from the router through two open doors. It shows a full wifi signal.
Is there something that I need to set up on the D-Link? I just selected DHCP as the internet connection, and connected to the 5Ghz Wifi.
Also, I am no IT expert, but when I look at the line history on the Vumatel portal, it appears that the line is disconnecting every 20 minutes. Screenshot of log attached. Is that normal?
Thanks for any assistance you can provide.
Chris
