ahf
Hi All
What is the max connections allowed on Vumareach (Afrihost)
TIA
TIA
Thanks, want to connect two family members via their cellphones.I use vuma Reach on Afrihost. 4-5 cellphones /PC/TV all all worked fine, albeit a bit slow at times if anyone hogged the line with updates etc.
Vuma Reach by default limits the number of devices you can connect to the ONT but you can login with details on the device to increase the number of devices allowed to connectHi All
TIA
Thanks for the tipVuma Reach by default limits the number of devices you can connect to the ONT but you can login with details on the device to increase the number of devices allowed to connect
Just don't mess with settings that you do not understand. You WILL break your connection and for Vuma to reset and reconfigure can take up to two days.Thanks for the tip![]()
Noted, thanks.Just don't mess with settings that you do not understand. You WILL break your connection and for Vuma to reset and reconfigure can take up to two days.
You can. You connect it to LAN1 on the Vuma router and set your router up for DHCP WAN. Set the Wi-Fi details to what you want and connect your devices.i want 15 devices and they said i cant have it.So if i got my own fibre router can i do it as there router i cant log into it///.It has a admin account i do not know the password to.
Ok this is great news,I work with alot of **** and got alot of phones and tablets.We only 2 ppl but the devices we got amount to about 15..You can. You connect it to LAN1 on the Vuma router and set your router up for DHCP WAN. Set the Wi-Fi details to what you want and connect your devices.
Keep in mind, all devices shares the 20/10 bandwidth so more devices in use = lower speed per device.
The limit on the Vuma router is there for a reason.
