Admiral Snackbar
- Jan 12, 2016
I basically wanna decorate my room with LED fans mounted together next to each other like a LED fan wall.
Kinda like this but with 9-12 140mm fans.
But obviously each fan has it's own wire, best way to go about doing this? It's purely for aesthetics.[/Q
I can only imagine the noise generated by 12 x 140mm fans trying to suck air through a wall.
You would have to get a large piece of rigid sheet metal or wood to mount them on and cut holes for each fan, the reason for this is to get space between wall and fans. Second thing i would get is a fan controller to control volts for best rpm so they don't drive you up the walls from the noise.
http://www.mantech.co.za/ProductInfo.aspx?Item=372M0031
Something like this for the power.
You can contact Mantech for a dial type switch too for fan speed control.
Edit: If you want to get fancy mount the setup on one of those monitor mounts with the pull out arm so you can tilt and turn then fan wall and use it as a actual fan.
More ghetto than having your room look like Liberace's room?Yeah that sounds pretty ghetto, I'm beginning to think this won't be as easy as I thought.
Liberace was a performer (singer and actor) who was known for his love of gaudy shiny things. He would approve of your colourful fan wall. You have the same tastes.Don't get the reference. I'm probably too young.
This took me 2 minutes. I'll show it to my dad and see what he thinks.
I must daisy chain all the wires though through a fan controller like suggested prior.
