war3 banlist that will work on lan?
Pe-Killer
Is there a war3 ban list that will work on a lan? or a program i can use to see the person who joined my games IP? I know a war3 banlist for lan is very useless most of the time because ppl can just change there IP. But at lans i go to like mayhem and rage everyone has a given IP they must use . But i get so ##@#$ mad when ppl quit my games then change there nicks and quit my game agian.
Anyone know of a lan war3 banlist or a program I can use at lan to see the ppls IP?? I really want one for rage.
Typing the following into a command prompt will give you a list of all IP addresses that you are connected to:
netstat -a
The following will give you the numerical port number and process, which is more useful:
netstat -abn
To get a command prompt: Start | Run | cmd | OK
You should be able to block the IP using your firewall. Hope it helps...
