contact roto tanks ,they sell complete kits and probably have preferred installers .good product and very nice people to deal withHello all
With the current water issues in GP, can anyone recommend an installer for a residential water backup? Jojo and municipal supply?
Borehole is financially off limits for me
I used Geezers plumbing of Fairland.Hello all
Is this simply fitting a tank on the mainline before it goes to the rest of the house? No pumps or anything? Just an inline tank?I’m currently getting a jojo installed. Just backing up municipal water atm and then will look at harvesting and purification options when I have more funds available.
Long term, If my neighbours agree, the plan is to pool together to get a borehole and join up to our tanks that way. Would require separate plumbing as I will only use that water for toilets, pool and garden.
My guess would be No. Jojos are normally low pressure compared to your main supply.Is this simply fitting a tank on the mainline before it goes to the rest of the house? No pumps or anything? Just an inline tank?
Also curious - I know when my water is cut, nothing comes out of the geyser. The water is trapped by (I think) a vacuum. Wouldn’t that be the same ?
Hello all
