Water In My Screen?
Mortymoose
In the Namibian desert...
With all the sand and dust blowing around in these parts of late, I decided to clean my screen with one of those LCD cleaning kits....
On reboot I found the below "Blob"
Screen still works fine, but now I have a watermark...
Oh! Bright ones, Pray tell....
1) Shall this go away with time.....
2) Can this be repaired?
3) Will this have any influence on the size of my prosate?
4) If I consume 12 cans of beer whilst staring at this watermark, will it appear smaller in size?
5) Should I just use tippex to block it out?
6) Should I brag to my peers about my cool unique design?
I thank you....
717395
Did you dunk the phone in the cleaning solution? If you leave it out to dry it might shrink. My wife's Huawei P20 Lite went for a 5 minute dip in a freezing pool. After a day of being off and drying it throughly the water marks in the screen are gone. Turns out the P20 Lite is mostly water proof.
That's a PC monitor
Firstly... are you sure it's water? Come on, own up!
Secondly, assuming it is water, it should dry up by itself, but will most likely leave a stain. To remove it is no small task, and involves disassembling the panel, separating the layers, cleaning them, putting it back together and buying a new monitor when you realize you buggered it up.
Buy a new screen, good time to upgrade to a 27"full HD
