veggie_mane
- Oct 11, 2010
Hi
Last night the geyser burst at my house and nobody was home so it pretty much flooded the house. Unfortunately the geyser is located in the ceiling, above the bathroom which happens to be next to the study where my pc is. Anyways the ceiling of the study filled with water and partially collapsed destroying my screen mouse keyboard and speakers.
My case however was sort of shielded because it stands under the desk. Some water has however entered the case. I have a CM sniper case if it helps. So basically water went into the top control panel of the case-where the usb,firewire etc. Connectors are as well as the power and reset buttons and fan controller unit. The hardrive is located below this in one of the top drive bays.
It is unclear whether water has got to it. So basically my question is what is the first thing that i should do? Atm i am leaving it standing to dry completely. All i need is the data on the hdd, the rest of the hardware is replaceable. Do i wait a few days and then try and turn the pc on? Or do i take out the hdd and take it somewhere for data recovery? Water may have gotten to the psu but its hard to say because i wasnt home when this happened, and when i did get home the priority was to turn off the water mains and the plugs etc. So by the time i got to check out the pc properly, it had already begun drying so i cant tell where the water has reached.
Please advise me on the steps i should take. As i said, the hdd is my priority, insurance can replace the hardware but not whats on the hdd. And plz dnt go on about how i should do backups, the external hdd where the backups are on is also ruined.
Any help will be greatly appreciated.
Thank you!
Sent from my GT-I9000 using MyBroadband Android App
Thank you!
