It's not your problem.Hi Guys
So my water meter has stopped recording the water flow.No idea how long it has been stuck like this.Anyone know how the billing works if at the end of the month the meter records 0 water usage?.Its not prepaid.
Hi yes in Joburg I am amazed that they are more lenient in CT usually its seems a lot stricter there with all the water shortages up that way.It's not your problem.
They will just bill zero usage, until the flags go up. Then they will come and swap out your meter.
This is what happened to me in CT.
Of course if you live in JHB or somewhere else, you will probably get an estimated bill of R 165 000 or something that you will need to pay first....
Nope not logged yet going to see again in a few days. Hope its not based on the previous bill though it was 3 times the normal .Did you log it? Just pay for the average amount you use, so if last month was still normal, pay that amount again.
Why for free?Man's got to eat^^ hahahaa
and offer to top up your neighbours pools as well for free
