LOTR
- Sep 5, 2013
Looking for some help from the knowledgeable folks at MyBB.
I am in need of a pair of water pump pliers (also called groove joint pliers, tongue and groove pliers or slip joint pliers) that has a jaw capacity of up to 140mm. It would seem that the required size of pliers would be 500mm or greater, however I am not finding a local supplier with something that big. Max I can find is 400mm at Builders, and that would appear to have a max jaw size between 90mm and 110mm. Maybe Google is also not being my friend today.
I can find them internationaly - plenty to choose from, but don't want to go through so much hassle for this one item.
Anyone know of where I could search further for this? I'm in the Northcliff/Fairlands (Jhbg) area.
TIA
TIA
