WDS and pppoe question..?
headstrong
Hi
I have 3 wrt54gl's in WDS mode and the central AP has adsl connected into one of it's lan ports
From my PC i can connect to adsl by making a WinXP pppoe connection..
My question is this:
How do I make one of the wrt54gl's establish a pppoe connection?
Simple enough
U have the username and password correct.
Change the setup around so the WDS modem's ethernet jack is plugged into a WAN port on one of the WRT's
Then set the WRT to connect to the internet using PPPoE with the username and password you got from WDS. Let it handle the DHCP and the others just point to it as gateway :)
