Hi all,
I have this Excel "tool" that we use at work which basically in it simplest form, have cells with values and its represented in pie charts and a heatmap for management.
Now, I want to make this tool/application look more modern/professional by porting to a web-based format.
I used jsp/php/asp way back in the day, but are unfamiliar with new developments. I want to framework/software that will be able to handle displaying graphs and charts (pie charts or the like) on the web. I want to attempt doing it myself and need a starting point.
The tool should be able to work with SQL Server as backend for the data, and will be mainly hosted in a company intranet, but individuals should be able to work locally/offline and "sync" back to the database when connected again.
I see things like different PHP frameworks now, asp.net, HTML 5.0, DHTML, flash etc.
Can anyone guide me in the right direction to achieve this web functionality?
Thanks in advance.
Thanks in advance.
