Hamster
Resident Rodent
- Aug 22, 2006
Being drawn and quartered is not punishment enough!PHP7 is easier, faster and all-around better than python for the web.
/runs
I see your Ruby and raise you a Visual Basic!Ruby can't do anything
FIGHT ME!
MongoDB + Node + Mongoose (+ Mongoose Compose for fun) + React will see you up and running in hours.Sure. I was just making a point.
Django and Rails however ships with SQLite by default. But since they are ORM based, you can simply just use that.
To be fair, I mostly use Mongodb these days, because it's quite smooth with NodeJS and I use Mongodb atlas for development - no local setup required as everything is cloud based.
The Bad Programmer is the one who leaves a trail of destruction in his/her wake. Yes, this programmer has figured out how to make a three-hundred-line method called "get_stuff()" that has all sorts of nested try blocks, handles exceptions (all of them) by dropping them on the floor, and generally writes hard-to-understand Bad Code.
JohnBeppu said:
I have a full house of GOTO statements.Oh yeah, here's my PHP card! Try be worse than that! MHUAHUAHUA!
ToucheI have a full house of GOTO statements.
FIGHT ME!
I'm 27 of age and have yet to decide on a career and was thinking of starting a web development gig and seeing whether or not it is for me. Up till now I've only been working for my father's company as a desk support nerd. I will first try the front-end of things and see whether or not I like it, if I do I would try to go full stack.
For the moment my only question is about the problem solving aspect of things and what exactly entails it. If web development is a form of programming and programming is defined in a number of contexts as creative problem solving within the constraints of computer technology, then what mathematical or logical problems am I expected to solve, and how would these problems change, in terms of both difficulty as well as their nature, over time as I get more experienced and my career progresses?
I would be very grateful if some real-world examples could be demonstrated as well as how I am to go about finding the solutions.
Thank you kindly for your time.
I heard this very argument asserted by numerous Rails devs... is it a DHH quote?There is a reason why Rails is famous with startups and that's because it lives up to it's reputation of quick MVP and maintainability and by the time the app is serving enough people where you need to start worrying about scale, you have enough money to pay for it. It's not only about the speed, it's also about investment.
The argument has its merits, but personally I don't like it though. It fosters a "not-my-problem" mentality at the outset since it is assumed another technology will replace Rails when scale becomes the focus.
Ah, NodeJS... the bleh middle ground choice when you can't pick between Python and GoRuby on Rails is dying which is not surprising at all. Learn NodeJS and Express JS.
It could have been PHP, if I had to pick between NodeJS and PHP I'd much rather pick NodeJsAh, NodeJS... the bleh middle ground choice when you can't pick between Python and Go
Yes, but it works.Ah, NodeJS... the bleh middle ground choice when you can't pick between Python and Go
Nobody picks PHP...It could have been PHP, if I had to pick between NodeJS and PHP I'd much rather pick NodeJs
Nobody puts PHP in a cornerNobody picks PHP...
