Hi bwana,
Can you PM me your client code or phone number so I can give you a call and we can figure out what the problem is that you're experiencing. Our authentication servers are currently running 100% so I'm not sure why you're unable to login.
Thanks and thanks but eventually all my accounts went pear-shaped . . . EOM I guess - we'll see where things go.Hi bwana,
Did you get your problem sorted? If so what was the cause and solution?
No - SMC.Do you use a Telkom 4-port ADSL Router?
