jetlee
Hi Guys
Shot in the dark, having some issues connecting to a machine inside my lan from the wan over port 22 (SSH). The port forward rule is in place, and I can easily connect from inside my lan .. am just wondering (before I pull my hair out) if Webafrica by default blocks certain incoming ports (in anyones experience) before I query it with Webafrica.
Summary :
Port 22 forwarded, can ping the wan address, cant telnet over port 22, also not over port 10022 (same config).
Not looking for technical resolution, just a comment if someone can definitevly say that certain ports / protocols are definately blocked on the wan port by Webafrica.
JetLee
Summary :
JetLee
