Weird 2013 Samsung F series problem
ZeroNeo
So
I have been using my 2013 F series Samsung to watch netflix for a while now. I have also lately been figuring how to setup plex to make my life easier when watching media in different rooms.
I know they are two different apps but all of a sudden I cant seem to connect to plex on my F series but still works perfectly on my older 32 samsung in the room.
When I try to use the app on the F series the screen just goes blank for about 10-20 sec its goes back to whatever source I was originally on when I pressed the smart key on the remote.
I changed regions back to SA and then back to the stated but the same thing and the another weird thing is that when i went back to USA it showed netflix as already installed. I also am not able to uninstall netflix
I am also getting a message from samsung saying that paid apps will not longer work from the 26 March.
Anyone having or had a similar issue and managed to find a solution.
I think the way the Plex app works has changed. I needed to login to my account that is also logged into on the server. The app connects via the account and not via a server address anymore.
yeah i noticed i had to do that as well
but would that be the cause my netflix not working?
Plex still seems to be working but cant get netflix to work now on my F series samsung
Netflix doesn't work any more due to the app and Samsung firmware having been updated so the region trick doesn't work.
Anyone know how to force uninstall Netflix from 2013 F series? Looks like its the same problem I had with the 32 where the version of Netflix and the version of Samsung software is the issue. I am hoping that is the issue.
Current TV software 1115 and Netflix version 4.005
I am still able to change regions just not able to uninstall Netflix. I reset of factory default and still getting the same issue it just sees Neflix straight away when I go to the store it doesn't give me the option uninstall.
Choose SA as a region and let it update. Give it a while and it will uninstall. Will be well surprised if you get it to work.
