Weird lighting issue
Heisenborg
Hi all
I drive a 1300 Sirion and this morning i switched the lights on and only the right side came on. When i switch to brights both work fine, but on dim setting only the one side works.
Its the same bulb for dim and brights right? So why wouldn't it be working on dim?
I appreciate any feedback
rakabos
Hi all
rakabos
Even though it's a single bulb it works on two separate elements, and one can easily go before the other. Change the bulb and you will have light again. :D
