WaxLyrical
The water in my tank boils to the point where the engine starts overheating.
Water is clear and clean so it can't be the gasket.Fan switches on so it can't be the thermostat.
The fan does spin quite high to compensate for the problem though.
Did a pressure flush to remove potential blockages but it hasn't helped.
Temperaure valve inlet broke recently but just did a bypass so the water returns directly to the engine, so that can't be it.Waiting for parts to replace it.
So what could be causing the water to overheat?
