Ok, not 100% sure if this is hardware related, but anyway. Today my PC started doing something very weird. It would randomly "black out" - in other words, unresponsive with a black screen. The PC, however is still running, so it didnt reset or switch itself off. I think it happened every time I bumped the PC (with my knew etc) - even a slight tap - but that could be coincidental. So I'd have to hold the power button or unplug it and restart the PC normally which would fix the problem until the next "episode" happened. Except, 15 min ago, I couldnt switch the PC back on. I re-inserted the RAM - nothing. I took out the CMOS battery - and it worked! Thinking my problems were finally solved I continued to boot up. When setting the system time, however, I was unable to set 17/07/2010. Every time i set "17" it jumped back to 1. I ignored it eventually thinking it had something to do with the OS being the RC version at one stage ( I tried upgrading the Win 7 RC version to full RTM version, but it wouldnt allow me, so I used some cheap trick to con the installer into thinking the version (2600) was sufficient to upgrade). But now my PC refuses to boot Windows which makes me believe the OS didnt do something right when bypassing the installer check.
Quite a confusing situation, I know, but any help would be much appreciated.
Oh, and I needed to use the Upgrade function on the installer as I didnt have anywhere to backup my 250GB.
