Weird SNR and attenuation numbers.
BCO
Slaapstad
Been having really slow and laggy connectivity lately on my 512 line, so I finally got round to checking my SNR and attenuation, and the results are a but weird.
Downstream I have good SNR and terrible attenuation (29.0dB SNR, 51.0dB att) and upstream I have useless SNR and good attenuation (1.5dB SNR, 22.0dB att.)
What could be the cause of this?
Wth, lol. No way you can achieve that SNR with that atten. Unless your router has a transmit power above the standard (s). Give some more details on the configuration.
What other kind of info do you need? I'm not too well-versed in these things :o
K, it's a Billion BiPAC 7401VGP
Modulation type is (I think) G.Dmt.BisPlusAuto
Not sure where to check the sync speed. :o
Ok, got my work router connected up. Now I have downstream SNR 25.5dB Att 46.5dB; upstream SNR 13 dB Att 2.55 dB.
Seems a little better. Does this mean I need to get a new router?
Which router are you testing with?
Every make of router will give different results, depending on the chipset it uses.
Looks better. If this router doesn't give problems, then I'm sure you know where the fault is ;)
The older Netgear DG843G v1-4, GT have a very good broadcom chipset which seems to help alot with low SNR and high Attn. So given your high Attn it might be a good idea to get yourself something like a Netgear DGN2000 and ditch the Billion as it's clearly not handling the Line attentuation well.
