Jam Sandwich
- May 15, 2007
So from the main switch I have a network cable that is POE going to a Cambium Networks outdoor wifi AP about 70m odd away, this outdoor unit also then feeds another AP point about 20m away from it.
I have some buildings that are struggling to get stable wifi (thick walls, lot of trees around it) so I was thinking of splitting this cable along its route and adding in a switch/T piece and then running in a cable to the buildings and adding in some more wifi routers.
If I split this cable I assume I will still need to get a POE switch to keep the Cambium unit powered?
Or would one of these T piece splitters work and still keep the power on the cable?
Im not sure if this makes sense but the closest place to the buildings for me to split the cable doesnt have any power nearby, so If I need to have a POE switch on the split then I will also have to add in an electric cable and a outdoor socket and box etc for this.
Also if I split the cable and end up adding in a new switch does this then mean I can go the maximum 100m from the new switch or is there a length limitation?
