Langes_CPT
- Jun 9, 2021
z
strange cause having a hikvision nvr/dvr is much simpler and "just works". note: i have a hikvision nvr with +- 5 cameras and have no problems.I have 16 cameras 720p but the Hikvision DVRs I have used are giving me so much problems. Someone built me a pc many many years ago with a dvr capture card and that thing worked flawlessly for 10 years before lightning struck it somehow. Then a professional security company installed me a Hikvison DVR and it did not last, fan packed up and everything fried. They then "upgraded" it and this thing throws away the recordings after a power failure and it is so difficult to export any recordings it made. I have to physically take the machine to their shop to export the data.
The custom pc was so much more user friendly and it did its job properly.
What do I need?
thats why you use the nvr cause there is no mucking around trying to find software that worksStart with the software.. the software will dictate your hardware needs in terms of ram, CPU and GPU.. you dictate your storage needs based on how long you want to store footage for..
Once you know hardware requirements, you will know what to get..
P.S good luck with the software hunt.. there are lots out there, some free, some paid for and you are going to have to dig in to decide which you like..
Yes, my hikvision just works..thats why you use the nvr cause there is no mucking around trying to find software that works
I am using ivms without issue..For those suing the Hikvision DVR units, which software do you use? It tried using the software that comes with the setup which is iVMS but I find it's such a pain to use. I'm now using Surveillance Client but I cannot use it to download footage. For that I have to go through Internet Explorer web browser.
