Whatsapp business help
marine1
A black hole in the universe - JHB
Suddenly i have this weird "my reply" button on the bottom left. I cannot get it removed or disabled.
Whatsapp support is absolutely useless the Ai support is retarded and cannot help.
Anyone else have this issue?
Using samsung galaxy S26 ultra and whatsapp business.
It is in the way when I want to type a message.
When I click it it gives me the option which is attached.
Screenshot_20260809_165236_WhatsAppBusiness.jpgScreenshot_20260810_012742_WhatsAppBusiness.jpg
Under Business Tools, did you enable the AI agent (or tried it)? Delete the agent if you did/want.
I did create an agent and took some searching to delete/remove it.
According to Gemini AI the bottom two options will become selectable when your agent is fully trained.
But you don't have any agents enabled or even created.
Since you are stuck, create an agent and see what happens. Can delete it later I suppose.
I even created it now and canceled it still same problem
I did so. Then canceled it and it hasn't gone away maybe I need to go back to whatsapp non business? But I imagine I'll lose my chats
Are you losing anything besides screen space?
It might be a bug that they fix shortly.
Have you tried using the account via Whatsapp web?
That may be a stopgap solution for the meantime
Did a fresh install, no backup restored and its the same thing, this function comes back. So sick of Whatsapp. 8 years of stuff is now gone and still have this irritating my reply button and Whatsapp support are worse than useless, relying on Ai
