Where them Python experts at...
WAslayer
Straight off the bat, I have no Dev background (unless you count bash scripting) and like started yesterday new to python and stuck on something:
Given two variables:
one = ABC
two = '{ "A": "B" }'
I need to replace B in variable two with the variable one:
two = '{"A": "one" }'
So that the end result is:
'{"A": "ABC" }'
Without altering the syntax/format of variable two, as that becomes a body for a POST request and the API is expecting that JSON body..
I have tried:
two = '{"A": " {} " }'.format(one)
And something similar as above, just using f strings as well something with a percentage symbol.. none worked and I am guessing it's because the value is encapsulated in single quotes..
In PHP I would hack with regex with preg
I am sure python have something similar
Try:
Code:
two = "{{ \"A\”:\”{}\”}}".format(one)
The \” allows you to embed double quotes in a double quoted string and the double {{ and }} prevent these as being used as substitution targets for .format()
PythonGuy :cool:
Try:
Code:
PythonGuy :cool:
Python Guy Indeed..!! You, sir, are the man..
This worked a treat..
I did try and escape the double quotes initially, however, had no idea you could do double parentheses..
Some needlessly complicated fun :p
import json
two = json.dumps(dict(json.loads(two), **{'A' : one}))
two = f'{{"A" : "{one}"}}'
{"A" : "ABC"}
f-strings were my first thought as well!
