Where to get a wireless AC access point?
DrJohnZoidberg
Table View
Browsing around now looking for a wifi ac access point but coming up empty.
I'm not looking for a DSL router with wifi, I want a plain wireless AP without any modem or fancy shmancy routing stuff.
What are my options?
Netgear used to make them.... I have one at home used in reverse i.e. to connect a wired ethernet device to WiFi. Can't remember what the model number was, but maybe searching with netgear in mind, might yield some results..
EDIT: have one at home... made by Fujitsu... got it from work a couple of years ago...
You do get cheapy wireless AP's but if I was you (and this is what I did at home) I'd get an old wireless router. You can get them for next to nothing at second hand stores or for free if you ask friends and family. Old routers are everywhere.
The cheapest TP-LINK at Matrix was R266 odd..
Or get a 2nd hand Linksys WRT54GL and install ddwrt on it
Highlighted because AC
