Where to get DC power connectors
mmacleod
Gordons Bay
Does anybody know a good place to get DC power connectors/jacks, I'm looking specifically for DC barrel connectors in the following sizes:
7.4mm exterior 5mm interior (Equivalent of an HP laptop power connector essentially)
6.5mm exterior 4.4mm interior (Equivalent of a samsung monitor)
I need some of these for various components of my 'off grid' setup that I will be doing.
I've tried all the places that seemed obvious to me like Communica and rs-online and none of them seem to have this sort of thing (they only have the smaller ones)
mm, no luck so far, still waiting for a response from one or two but doesn't look promising.
Anyone know any other places?
If I look at this you need a 5.5 x 2.1mm for the HP
It isn't actually for an HP - it is just happens to be the same size as an HP plug (or at least some HP plugs) - as for the measurements, either HP have more than one adapter size (not that unlikely given how many products they have) or rabtron are wrong (also not entirely possible).
" DC PLUG I/L 4,3X6,5MM W/1,4MM CENTER PIN L=9,5MM
The minimum order quantity from the suppliers overseas is quite high, so I am not too sure when we are getting these in."
Meh, I'll just hack a connector out of wire and try grab some from overseas at some point. Thanks for the various links though!
