Where to get long VGA cables?
PostmanPot
Hi all
Where can I get a long VGA cable in Cape Town? Might need to be of a custom measurement.
Cheapest that I could find was Prophecy : 20m for R200....
Doesn't look like it. I might just have to join 2 male VGA cables to get the right length.
Possible? Before I FSU. :D
Bump. Last resort is joining 2 cables to get 1.8m exactly - possible? :)
yeah... until the 3rd time you move your laptop on your lap and the plugs where they join pulls out .... then u will think 'why didnt i just spend the R200 for a proper cable' :)
That isn't a possibility, judging by this thread. Unless you know where I can get a 1.8m cable? :D
Will this length work?
Looking for some help - found a 50m VGA cable here in the UK (http://www.aandcaudio.co.uk/vga-cables-b34) but unsure as to whether it will work...
- does length matter?
- does quality? (should I opt for a brand name - if so, any suggestions?)
Sorry for the random post from the UK, but typed 'long vga cables' and this was where it sent me!
Thanks guys!
