Good day to all the mybb fanbois!
So, I have always gotten excellent help on here as to what to buy, and I am in the market now for a tv.
My budget is R7000 max. Want to get an asus mm player as well, so cant go higher than that.
Also, I dont want anything smaller than 40". I see hifi corp has the BYD 46" lcd for R5000. Has anyone got one of these? Is it a worthwhile buy? Dont fully trust hifi corp, but a mate bought a 40" led from them a while ago, and its perfectly fine. Could be a lucky buy.
Anyway, let me know what you would get, and why. Any info would be appreciated.
Thanks a lot guys
Don't touch ByDesign or Sansui, these are both Hifi Corp's own brands which are utter junk, worse than Sinotec. Other than that, if you find anything from Samsung/LG/Sony cheaper at Hifi Corp, by all means go ahead and buy from them. They
do not grey import these brands any more (I suspect my friend above thinks they do?).
Your choice depends on what you want the TV for. So, what are you going to be using it for?
At the entry level of the market (your ± budget), plasma wins because it produces better blacks and more natural colours.
Entry LCDs have washed out colours, entry LEDs are even more washed out (overly contrasty). But, LCDs are better for PC work because they suffer less from image burn-in. Entry plasma is HD Ready/720p where entry LCD is Full HD/1080p.
"LED" is pure marketing gimmick, only the back-light is different (edge-lit by LEDs opposed to CCFL in LCDs); the back-light passes through the identical LCD matrix that LCDs have. 100% the same tech, only the back-light is different. LED LCD is slightly brighter. Colours are less natural as they are more contrasty, common folk seem to prefer this not knowing that it's actually inaccurate. LED LCDs can also suffer from uneven lighting. In summary, they are
not worth the 10% - 15% increase in price. The only LED TVs worth considering are those back-lit by a full array of LEDs, which have local dimming. These types of TVs are very, very expensive.
HD/SD content, gaming, sport, TV = plasma
FHD content, PC work = LCD
Plasma
Samsung PS43D450
43" 720p = R5,500
Samsung PS51D450
51" 720p = R7,000
LCD
Samsung LA40D530/D550
40" 1080p = R6,000
Samsung LA46D530/D550
46" 1080p = R8,000
One other interesting thing is that to get the full benefit of full HD content, you need to sit 1m from a 32"/1.5m from a 40"/2m from a 50". So if you
need full HD, you have a Blu-ray player or whatever,
but you sit like 2.5m+ away from the TV, you may not necessarily need FHD.
