That_JC
After everybody helped so nicely to convince me that gearbest.com is worth using, I have now narrowed my smartwatch phone options to three choices:
http://www.gearbest.com/compare-363519_446744_365830-21_21_21
Requirements in a smartwatch:
Any thoughts/suggestions?
[UPDATE: 2017.01.23 @ 16:17]
Choice has been made! http://www.gearbest.com/smart-watch-phone/pp_365829.html
ZGPAX S99
Android 5.1 1.33 inch 3G Smartwatch Phone MTK6580 1.3GHz Quad Core 512MB RAM 8GB ROM Pedometer Bluetooth 4.0
Parameters:
Display: 1.33 inch screen
CPU: MTK6580 Quad Core 1.3GHz
GPU: Mali-400MP
System: Android 5.1
RAM+ROM: 512MB + 8GB
Bluetooth: V4.0
SIM type: Nano SIM
Functions: Find Phone, Pedometer, Heart rate measurement, Sedentary reminder, Water remainder, GPS, Gravity sensor, Remote control music (When connecting bluetooth between smartphone and S99, you can use this smartwatch as remote control to control music play in the phone. S99 itself dosen't have the function playing music.
Network:
GSM: 850/900/1800/1900MHz
WCDMA: 850/2100MHz
- SIM - I need it to work with a sim as I want to call for help if I run into trouble during a walk/jog
- Space - Enough space to pre-download a decent playlist via Google Play Music, so expandable memory or 8GB storage should be best
- OS - Android 5.1 works better as Android wear 2.0 with 3G is coming out later on very pricey smartwatches.
- LOOKS - A round watch face just looks prettier!
- Fitness Tracking - Not such a big priority as I'm looking to replace the cellphone (connectivity + music), not my Fitbit, with which I'm very happy.
ZGPAX S99
Parameters:
GPU: Mali-400MP
System: Android 5.1
Bluetooth: V4.0
SIM type: Nano SIM
Network:
WCDMA: 850/2100MHz
