Which Ultrabook - help??
Nimz
Durbz
okay im stuck deciding between these 2 models:
HP Envy 4-1030EL
1.7 GHz Intel Core i5-3317U Chip Intel HM77 Express
Memory,4 GB DDR3,Memory Max,Supports up to 8 GB DDR3 (2 DIMM)
Video Graphics,Intel HD Graphics 4000 (up to 1.65 GB)
Hard Drive,500 GB SATA (5400 rpm), Up to 24 GB partition for system recovery
32GB SOLID STATE DRIVE
Display,35,5 cm (14") HD BrightView LED-backlit (1366 x 768)
Network Card,Integrated 10/100/1000 Gigabit Ethernet LAN
Wireless Connectivity,802.11b/g/n; Bluetooth
Sound,Beats Audio with 2 speakers and HP Triple Bass Reflex Subwoofer
Keyboard Full size island-style
External Ports,Multi-format digital media card reader1 HDMI
1 headphone-out
1 microphone-in
1 USB 2.0
2 USB 3.0
1 RJ45
Dimensions,34 x 23.58 x 1.98 cm
Weight,Starting at 1.8 kg
Power,65W AC power adapter 4-cell Li-Ion polymer
Camera,HP TrueVision HD Webcam with integrated dual array digital microphone
Operating System:Windows 7 Home Premium 64
1 YEAR HP CARRY INN WARRANTY + Free Bag
R6300 new
Lenovo U300s
13.3" HD LED
CORE i5 2467m 2.3GHZ TurboBoost
4GB DDR3 RAM
128GB RapidDrive SSD
INTEL HD3000 GRAPHICS
HD WebCam, MIC, HD STEREO SPEAKERS
BLUETOOTH 3.0, WiFi, USB 2.0 & 3.0, HDMI
WINDOWS 7 HOME PREMIUM 64 BIT
R6000 new
Looks like the HP is edging it because of the graphics and storage space
HP...newer gen proc. To lazy to google but eyeballing thse model nums I'd think the top CPU is an ultra lower power one while the bottom is std. Ultra low is preferable @ bat life. Battery info btw you did not list. ;)
If you can afford it upgrade the SSD to 128 though. 32 is barely enough for OS.
HP claim 8 Hours - im sure normal usage should give me about 4?
Lenovo unknown
i wouldnt buy an ultrabook that doesnt have a touchscreen now
Went for the Hp Envy
Getting delivered tomorrow :p
Nimz - how'd you like it? Happy with the decision?
@ Ninz, Please can you PM me the Place that you bought the Laptop from please, also looking for one.
Since I am getting so many PM's about where i bought it from il post the link here:
Bidorbuy
