White screen on huawei U8120. HELP!!!
Ndanileka
Tarantula Nebula
While I was opening the camera app yesterday the screen just turned white, tried using the power button to switch it off and it didn't respond so I had to pull the battery out, when it booted it just stayed white.
Tried recovery mode same result the screen stayed white.
I connected it to the pc using MyPhonExplorer and took a screen shot it showed the normal home screen, so used I it to navigate through the phone by refreshing the screen shots and did a hard rerest that didn't help it stayed white.
The same white screen thing happen 3 weeks ago while I was playing music, that time I just pull the battery out and everything worked again. I'm not sure if its a software or hardware problem and how to fix it.
The phone has a custom rom and I have been using it for the last 4 months with no problems.
