Why I lost my Connection.
HowTo
East Rand
Hi All,
Hope this will tread will help someone.
I got disconnected on a regular basis.
I was under the impression it was Vodacom.Sorry..!!!
When I spoke to Network Tech support he said it was not from their side.
That made me look at my system.
I installed Nokia PC Suite twice.
Yes I uninstalled the nokia Suite before re-installing.
I run WinXP64 at home.
It seems when un-installing Nokia PC-Suite it does not uninstall all related drivers. When I looked in my Control Panel under Install remove.....Windows components. I found a couple of Nokia Drivers that where left from the previous Nokia Suite. When I removed them all did a fresh installation all was ok.
So far I havr not lost a connection.:)
Regards
Hi All,
Regards
Can they really see that or is it an excuse for a bad link:confused:
