The usual off the shelf AV senders like the Ellies one , can transmit AV+remote blaster signals up to 30m(claimed) over 2.4Ghz. This range is not good enough for me.
I want to know , if i add a 2.4Ghz Wi-Fi Signal Booster like http://www.sparcotech.com/products/amplifiers/BA24j.asp
to an AV Sender with aerial , will this improve my range ?
Im looking at going about 70m-100m and maybe through a few walls.
Or what are my alternatives ?
What about Poynting Long Range Antennas http://www.poynting.co.za/pressnews.php?id=19
Is it possible to use their long distance antennas and possibly make the AV sender send using this external wifi antenna? Any help would be appreciated.
