I have set up a wifi bridge between two locations using two RB911 routers. I used the default setup, put them both into PTP bridge mode, one server, one client.
The connect to each other perfectly and I can open both routers from either location, however I cannot see any ip's beyond the router. All I have done is use the quick set wizard in Webfig. I have been told that it creates the bridge and configures everything for a simple bridge.
Is there anything further I need to set up?
In addition, I would like to have a dhcp server at each end so that if the link goes down both sites will still work. Both locations will had adsl, but I dont think that will be a problem in itself since I will just use different gateways, except that the adsl routers are also the dhcp servers. I understand that I would just make a certain range available in each location, but how do I prevent the client machines from getting ip's across the bridge?
