Johnatan56
Hello everyone,
I have a WiFi-issue, the WiFi adapter can pick up all the neighboring networks, but it cannot pick up my own one or the extension of it. It worked yesterday without an issue, booted today and I have no WiFi connection to my network. LAN cable works.
The other 2 laptops can connect and are accessing the internet without an issue, the android/blackberry phones also pick it up and even the iPads can pick it up.
Things I have tried:
Flushed network
Reboot
Reinstall drivers (used 3 different drivers)
Installed new drivers from windows update (used LAN cable)
Disable and re-enable the device
Deleted the network profiles and manually set them up multiple times
Any changes I have done: None, I stopped windows from updating yesterday, only with reinstalling drivers has windows updated. No new programs were installed either.
Device: 802.11bgn 1T1R Mini Card Wireless Adapter
Any advice is appreciated, its a MSI CR620 with a new HDD added a while ago and added RAM. It's a travel device, so WiFi is required, else I will have to find a new cheap laptop.
Flushed network
Reboot
