Wifi range extender
Gamebot145
Hey guys,
I want to get a wifi extender but the place where I need the extended range does not have any telephone jacks or whatever they are called. I can plug it into a power socket though.
Do any range extenders have the ability to extend range without connecting it to a telephone Jack?
Hey guys,
Range extenders uses Power over Ethernet (POE), you have a base unit connected to your Internet router, and then satellite extenders plugged into the power grid in the building. The Internet stream is then transmitted via the power-lines and each extender becomes a hot-spot.
BTW, figure out why it's not called Ethernet of Power ;0)
Huh? No that's the exception rather than the norm. Range extenders usually connect to the main router either via wired ethernet or wifi.
@OP: I'm using this one: https://www.incredible.co.za/netgear-wn2000rpt. Works great...
Please clarify the "Huh?" :) I recently installed such a setup in a guesthouse, which was my first experience. The convenience of POE was that I didn't have to lay network cables, I was under the impression that's the norm. Maybe I'm totally misunderstanding your comment, [waiting to receive enlightenment]
Not all extenders use PoE, hence it's not true to state it as such... :)
I could be wrong, but I think you have your terminology mixed up. I believe you are referring to ethernet over power or powerline adapters, such as:
http://www.pcadvisor.co.uk/test-centre/network-wifi/18-best-powerline-adapters-2015-uk-may-3490638/
