I've got a D-Link DI-624 wifi router, which I have been using to connect my PC's at home successfully.
I've now added ADSL to the equation by plugging a Billion 5100SM ADSL modem into the WAN socket of the D-Link, and set the router to dial out automatically.
Problem:
I can't connect to the internet from my PC! BUT, I can ping internet sites by using the D-Link's PING test tool within it's own web configurator. This means that the router is connected to the Internet, and I'm connected to the router, but I can't connect to the internet...
Any ideas?
By the way: The D-Link won't assign a DHCP IP to my PC, which is set to "Obtain IP Automatically" in Windows Server 2003. The only way I can access the network is when I set a static IP to 192.168.0.200. What should I set my Default Gateway to? The DLink IP or another one?
Thanks!
Problem:
Any ideas?
Thanks!
