Wifi router for several devices
RickyGC
Hi guys,
I've got 20mb fibre through fredd/ttconnect and the router they supplied me with is a TP-Link TL-WR940N. I'm just not sure if it can handle the traffic I want. The reason I say this is, some of the devices simply don't want to connect at times or struggle to keep a connection and worst of all would just be slow.
At the moment I've got 12 wireless devices connected and I probably use 5-6 at the same time with more coming soon.
I mostly stream Netflix / Dstv now / Youtube / Twitch, play games online and have my laptop and phones connected for work / social media use, so nothing out of the ordinary I think.
I also live in an apartment building with several other wifi ap's around.
The only solution I can think of is getting a really expensive router with all the bells and whistles that can handle the traffic I want and take care of the heavy interference.
Is this the right way to go? And if so, which routers should I be looking at?
The two I've looked at are the Netgear Nighthawk Pro Ac4000 XR500 Gaming Router & TP-Link AC5400 Tri-Band Wi-Fi Router
Any other help or suggestions would be appreciated.
Have you tried setting the channel to e.g. 1 instead of auto?
That router is a quite cheap R450 one, but it shouldn't drop.
The older version: https://forum.tp-link.com/showthrea...v2-Dropping-Connection-Needs-to-restart-after seems to have your problem as well though.
Personally running an Archer D5 on a 100Mbps line, not having any issues with about (checks router page) 3 ethernet + 9 wireless devices currently connected and 2 are currently wireless streaming YouTube 1080p (phone and TV).
Half those wireless devices are on the 5GHz band though, just a lot more stable/faster throughput.
Post your budget and area you need to cover, if possible a quick floor map. If one device can cover everything, then a one-device solution could be fine, but I really don't see the point in a R5k router when you could probably get yourself 2 ubiquiti routers instead and get better coverage.
I use these in my house, and we have the same in our office as well:
https://scoop.co.za/ubiquiti-unifi-dual-band-ac-lite-ap.html
These APs are really good if:
* You use multiple in your house (although one in a central place also works well).
* You want to ceiling mount it.
So if you are only going it have one AP and place it on a cabinet, Ubiquiti may not be the best. In my case I only have one, but the ceiling mount meant I could place it in a very central area (above a staircase), with good coverage over the entire house.
Another thing to consider is that you need to run control software somewhere - either on a home server if you already have one, or
using one of these: https://scoop.co.za/ubiquiti-unifi-controller-cloud-key.html
Technically you only need this when configuring the AP, but it's better if the control server is running all the time.
From: https://mybroadband.co.za/forum/threads/which-ubiquiti-unifi-ap.926966/
And they're substantially cheaper than that R5k.
If the area isn't large, maybe a MikroTik: https://scoop.co.za/mikrotik-hap-ac2-dual-band-wifi-router-5xge-rbd52g-5hacd2hnd-tc.html is pretty good for its price point. EDIT: slightly cheaper at Takealot: https://www.takealot.com/mikrotik-hap-ac-lite-dual-band-wifi-router-black/PLID44670409 (Mikrotik's best and worst selling point is that its interface/controlling options are great, but can be complex for those that are inexperienced in network set-up)
If you don't want to bother with that/is too complex, look at going: https://www.wootware.co.za/asus-rt-ac68u-wireless-ac1900-dual-band-gigabit-router.html , again, substantially cheaper and should deliver more than adequate performance. (Reviews: https://www.techspot.com/products/routers/asus-rt-ac68u-ac1900-80211ac-router.94935/ )
There are others on this forum who should be able to give better recommendations.
Get the Tenda AC something mean looking thing, should be perfect for this.
If you want to dabble a bit and go through a massive learning curve then get a Mikrotik (would work better, but required you to waste hours of your life debugging)
Thanks for the recommendations, the two things that I really like about the other routers other than dual/tri bands is MU-MIMO and beam forming on the tp-link. Does any of the other cheaper options have MU-MIMO?
