wii fit not working on my machine
silkman
I have an NTSC machine which I purchased when I was in Canada. my wii fit disk that I bought here obviously does not work on it. is it possible to exchange it for an ntsc one? if so where can i do this?
thanx
if u run the softmod on it u can play ntsc and pal games on it, just google softmii
thanks but since I am not too clued up on technical stuff, is it possible to mess my wii up ? what version do u guys suggest i use and if anyone has guide I will appreciate the link
check out http://yafaze.com/forums/viewtopic.php?f=46&t=113
there's a step buy step guide, follow it to the word and you'll be fine,
just follow it step by step, there is risk involved but if you follow the
guide step by step u'll be fine, i've done six machines alreay 100%
success rate and I ain't too tech savvy myself. also if you mess up
it is recoverable with the semi-brick....
