Will iBurst USB modem work with Mweb Technicolor router?
Kimberly Guest
Hi everyone
Apologies if this has been answered elsewhere; but, after 3 unsuccessful hours of searching the internet (chewing through a *bleeeep*ing fortune of mobile data) I'm feeling about as technologically- and internet-savvy as my 75 year old mom (she's going to conquer SMS any day now... I hope).
Anyway I would be eternally (and then some) grateful if someone would tell me what the chances are that the iBurst USB modem will work with the MWeb Technicolor routers?
I don't know which superhero modem it is (these links no longer work I'm afraid) so here is a pic instead:
The Mweb router is Technicolor TG589vn v3 Router:
Full Specs:
(With thanks to psion's linkhttp://mybroadband.co.za/vb/showthread.php/595497-Any-Specs-on-the-Free-Mweb-Router-and-Range-Extender-Offer?p=12063065&viewfull=1#post12063065
Hardware Specifications
Interfaces
WAN RJ-11 DSL line port
Interfaces LAN
4-port autosensing 10/100Base-T auto-MDI/MDI-X Ethernet LAN switch
1 USB 2.0 host/master
Wi-Fi IEEE 802.11b/g/n on-board
Extras
WPS button
ECO button
Reset button
Power button
Dimensions
195 x 60 x 230 mm (9 x 2.4 x 9.7 in.)
AC voltage
100-240 VAC (switched mode power supply)
Temperature
0° - 40° C (32° - 104° F)
Humidity
20 % to 80 %
DSL Modem Specifications
Supports multi mode standard
ADSL compliance
ANSI T1.413 Issue 2,
ITU-T G.992.1 Annex A, B (G.dmt),
ITU-T G.992.2 Annex A, B (G.lite),
ITU-T G.994.1 (G.hs)
Maximum rate: 8 Mbps for downstream and 1 Mbps for upstream
ADSL2 compliance
ITU-T G.992.3 Annex A, B, L, M (G.dmt.bis),
ITU-T G.992.4 Annex A, B, L, M (G.lite.bis)
Maximum rate: 12 Mbps for downstream and 1.5 Mbps for upstream
ADSL2+ compliance
ITU-T G.992.5 Annex A, B Maximum rate: 24 Mbps for downstream and 3 Mbps upstream
VDSL2 compliance
Up to 17 MHz profiles (POTS/ISDN)
Management
Customizable user-friendly GUI via HTTP and HTTPS
Unified management interface (MBus)
WAN port auto-sensing: Automatic selection and configuration of WAN interface
GUI-embedded Easy Setup wizard
On demand remote GUI assistance (helpdesk)
Web-browsing intercept (install / diagnostics)
PC (wireless) Technicolor Gateway Setup wizard
TR-069 CPE WAN Management Protocol
TR-098 Internet Gateway Device Management
TR-111 home network device management
TR-064 LAN side configuration
Zero-touch autoprovisioning
Services
Printer sharing
Content sharing
Samba file server
UPnP A/V media server and control point (optional)
Certified DLNA® DMS
HDD file systems: FAT32, NTFS (optional)
Metadata support
Remote HDD file access
3G USB adapter support
URL- and content-based website filtering (optional)
Wireless Performance and Security
Wi-Fi IEEE 802.11b/g/n access point Wi-Fi CERTIFIED
WPA(2)™-Personal, WEP™
Wi-Fi Multimedia (WMM)
Wi-Fi Protected Setup (WPS™)
Up to 4 BSSIDs (virtual AP) support
Security and service segregation per SSID
Dynamic rates switching for optimal wireless rates
RX/TX switched diversity
Manual/auto radio channel selection
Security
Stateful Packet Inspection Firewall (SPIF)
Customizable firewall security levels
Intrusion detection and prevention (DoS, SYN Flood, Ping of Death, Fraggle, LAND, Teardrop...)
DeMilitarized Zone (DMZ)
Multi-level access policy
Networking
Symmetrical NAT with application helpers (ALGs)
Game and application sharing NAT port maps
DHCP conditional serving & relay, DNS server & relay
IGMPv3 proxy
IGMP snooping
DHCP spoofing
Flexiport (automatic selection of Ethernet port bridged IPTV)
IEEE 802.1q VLAN bridging, multiple bridge instances
IPv6 ready
Quality of Service (QoS)
ATM QoS
UBR, VBR-nrt, VBR-rt, CBR shaping, queuing and scheduling
CLP tagging
IP QoS
Flexible classification (ALG aided)
IP rate limiting (two-rate remarking/dropping)
DSCP (re) marking
TCP ACK optimization
Dynamic link fragmentation
Per service class connection/resource reservation
Ethernet QoS
Priority or C-VLAN/S-VLAN tagging Switch port queuing and scheduling
Wireless QoS
WMM (BE, BK, VI, VO access categories) queuing and scheduling
Yours in exhausted desperation,
Feef
Don't think it will work, those USB are for 3g dongles usually
And the IBurst needs its own drivers that not the same,
You have a slightly different IBurst than mine, could try, but I doubt it will work.
