will my Nokia N78 work in UK
maumau
Northwold
hi, does anyone know if i can take my Nokia N78 to UK and use a pay-as-you-go card there? thanks
Phones supplied by Vodacom/MTN/CellC and Virgin by law may not be locked to a specific network so yes, it will work. Buy a phone in the UK and try use it here and you will suffer....you have been warned. :-)
tks
oh goody - at least that saves me giving even more dosh to MTN. thanks for the advice
Only if you buy pre-pay and even then provided you buy a Virgin Mobile Pre-Pay they will give you your Network unlock code once you have loaded £30 of airtime. You do not get charged anything for the code!
If buying a handset in the UK insist that it is not network locked; it will cost a little extra but it will usually be considerably cheaper than buying the same handset here!
And in Japan?...can i go there, buy prepaid and use it in my phone?
I found the best pay as you go package seemed to be from Orange. On the "Camel" package you can phone back to SA at 5p (others charge 20-30p) per minute as well as used Skype ,Nimbuzz and messeger. Very good value for money.
T-Mobile block VOIP apps.....I dont know which others do.
